Forsale Husky 60 gallon Air Compressor
infidel
I am looking to sell my Husky Compressor since I no longer use a blast cabinet and do not require a lot of air/CFMs at once. IT comes with the wiring required to run it into your Fuse Box and the female plug that is needed for the male plug from the compressor. It is in great shape and will require (2) people to lift and a truck or trailer to haul.
350.00
Husky 60 gallon Air Compressor is perfect to perform most of your tasks. It has a big 60 gal tank with a cast iron, twin-cylinder compressor pump.
It offer 11.8/10.3 SCFM at 40/90 psi air delivery and maximum pressure 135 psi. Powerful 3.2 HP motor provides significant air to multiple power air tools. Twin cylinder, cast iron pump delivers 1070 RPM. Husky 60 gallon compressor is a stationary compressor, which means that it is much more difficult will be move than portable one.
This 60 gal air compressor have oil pump therefore it require more maintenance than oil-free compressors. It’s recommended to have additional bottle with air compressor oil for them and if oil pressure in the pump will be lower than recommended by manufacturer, you should add some oil to appropriate level.
If you are looking more info about Husky 60 gal air compressor then there is no need to explain to you how can be useful additional air tools like spray gun, nail gun, air hammer, etc. This air compressor is usually used at small auto repair shops. For home use this compressor is not very practical, since it hasn’t wheels it will be quite difficult to move it through your workspace.
