07-09 Shelby GT500 Twin Turbo System
Hellion has developed the one and only power adder needed for your GT500. This twin turbo system is available for use with the factory supercharger,
aftermarket supercharger, or with an optional sheet-metal intake for use without supercharger. All three variations of the system are capable of producing anywhere between 550-1200 hp.
This system is the first twin turbo GT500 kit available for sale in the country and features several unique and innovative features. The GT500 system requires absolutely no cutting or modifying of the body or chassis, nor will it require any relocating of engine accessories or systems. This means there's no moving of lines, tanks, hoses, etc.. making installation much easier than other power adder systems. Also, the kit is a true bolt-on system, meaning that there's no additional equipment or modifications required to install the system (read: no hoods or K-member spacing, etc...). This means that you can return your rare collectible performance car back to it's factory state by simply unbolting the turbo system and re-installing the factory intake tubing. So there you have it, a one-system solution for achieving any horsepower level you desire.
OTTSKEE
those turbos look like they are the size of softballs. what are they, like 5lbs boost???
4CEFED
pretty much it' the best way to run them both is to lower the blower pi down to get a compound setup at around 16/17lbs with blower and turbos(pump gas), this way the blower is barely moving keeping IATs in check plu giving you that intand tourque and turbo topend.
thats like the kit they have for the termy. they put it on an 04 snake with completely stock engine and driveline. fuel system upgrades were a must, but they make 1000rwhp. the rear axles were bending on the dyno
Shane361
Compound boost from Hellion has been around for well over a year. They have always talked really big HP but it doesnt seem to have caught very much. Great concept to get the best of both worlds but I would think it would be a tunning nightmare. Very very interesting thouugh...WHINE BLOW OFF WHINE BLOW OFF..NICE! -Shane
