Baer Brakes brings the another dimension to stopping with the T4 Caliper
<div>Baer Brakes new product that debuted at the 2009 SEMA show is another in the long line of durable and affordable performance brake calipers from the Phoenix, Arizona based Company. We talked with Todd Gartshore of Baer Brakes about the new T4 Caliper. Todd explained that the T4 caliper had some of the best features in modern brake technology in an affordable package. From the four staggered stainless pistons with road going weather seals to a high temp powder finish, the T4 calipers offer increased driver control and predictable performance. <br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_3802.JPG" border="0" alt="" /> <br />
Gartshore pointed out that the T4 calipers are "Machined from extruded alloy billets with 6 cross bolts.” Most calipers in this class use 4 cross bolts, so the T4 has an added level of security with two additional bolts per caliper. The T4 calipers also feature internal fluid passages, which means no external tubes or outside bleeders. These calipers bleed at only one point.<br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_3806.JPG" border="0" alt="" /> <br />
Other features of Baer Brakes T4 Calipers:<br />
<ul><li>Stainless abutment and spring tensioners<br /></li>
<li>The T4 pad shape is common to the '98-02 Camaro OE brake pads<br /></li>
<li>Corrosion Resistant<br /></li>
<li>Easy to bleed<br /></li>
<li>Available in Red, Silver and Black colors<br /></li>
<li>Internal fluid transfer<br /></li>
<li>Ultra smooth clean appearance</li>
</ul><br />
For more information on the T4 Caliper and other Baer Brakes products, visit the Baer Brakes website at <a href="http://www.baer.com/" target="_blank">www.baer.com</a><br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_3807.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_3805.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_3804.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_3803.JPG" border="0" alt="" /></div>
