Can I put 03 cobra heads and supercharger on a 96 cobra?
Here some good info I found.. Tommy
stan's96snake said:
can i put 03 cobra heads and supercharger on a 96 cobra? if so what other changers or upgrades will need to be done?
Yes. You can, just pay attention to the coil packs and coolant routing if you use the eaton. It may be worth your time and effort to relocate the coil packs to the firewall. One thing you WILL need without a doubt if you use the eaton, is the 03 timing cover, the crank pulley and balancer, the alternator bracket, the tensioner and knock sensor from the 03 (thats optional if you stick with the 96 computer). The timing cover bolts on perfectly except for one stupid bolt, which you can put some RTV silicon in, and be good to go. Your B-valve covers will work, but your stock 96 exhaust manifolds wont, so you need the 03 cobra manifolds too. Also keep in mind, the 96 computer runs in return-style fuel configuration, so you need to use a different set of fuel rails than what the 03 has, along with an FPR. Just so you know, this swap isnt easy... I was swapping a 98 cobra block, forged internals (pistons,rods) 03/04 cobra top end with eaton with 98 computer and PMS into a fox. Thats way above what your doing, but the head and blower swap isnt a stroll through the park.
ears
you most certainly can, however despite popular beleife, the b heads actually respond much better to boost than c heads. it has to do with the split runners! i have the info on another thread around here somewhere. so in all reality. the car would respond better with the b heads on it, and its really not too hard to fab up a plate to adapt a blower to those heads. i have prototypes mocked up at the house.... easy for a good fab shop!
Stick with your heads. IF you like the Eaton, get it ported. If not Go for a Whipple or Kenne Bell. Hope your bottom end is built. And TURN UP THE BOOST!!
ears
yea but be carefull,,,, kb does make a kit for the 96-98 cobras but you have too keep the boost low. its damn near impossible to fab up a good intercooler for it. and it dont have a bypass valve neither!
