<div>The one company that everyone knows for making the classic red glass pack muffler that can be heard from towns away is back again. This time it is a new, compact muffler that is designed to do very much of the same. The Extreme muffler was originally designed to help make turbo diesel trucks louder, but was quickly adapted by racers as a solution for a low restriction muffler in classes that required them.<br />
• Straight through wing plate design that delivers an extreme sound<br />
• 100% welded, aluminized steel, and painted with a shiny red finish<br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_2739.JPG" border="0" alt="" /> <br />
<b>2010 Camaro Cat-back</b><br />
As we mentioned above with the Extreme line of mufflers is carried into their 2010 Camaro catback. The Camaro comes overly quiet from the factory and if you want that classic muscle car growl, this might be your exhaust. The entire exhaust kit is aluminized steel to keep a low cost and a X-pipe to help with proper flow. Also if you want an even cheaper version, Cherry Bomb offers an axle back in which you cut off the factory mufflers and C-clamp on the Cherry Bomb axle back. The piping is all 2.5” but there is also a 3” kit in the works.<br />
• Aluminized steel to keep costs low<br />
• Extra loud Extreme series muffler<br />
• 2.5 and 3 inch tubing available<br />
• Included X-pipe<br />
• Polished tips<br />
• V8 and V6 applications<br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_2733.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_2734.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_2736.JPG" border="0" alt="" /> <br />
<b>Catalytic Converters</b><br />
Cherry Bomb has been making replacement catalytic converters under their sister company for some time. Now, they have decided to stamp them with their Cherry Bomb branding name. The list of converter applications include pre OBD1, OBD1, and OBD 2. They are also working on direct replacement converters that are California state legal.<br />
• Larger Capacity <br />
• Stainless steel construction<br />
• Ceramic/metal converter elements<br />
• Pre OBD1, OBD1, and OBD2 applications<br />
• Larger front element helps eliminate check engine lights<br />
Check out more at <a href="http://www.cherrybomb.com" target="_blank">http://www.cherrybomb.com</a>.<br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_2740.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/689/IMG_2741.JPG" border="0" alt="" /></div>
