<div>Currie Enterprises is offering bolt in Ford 9 Inch Rear Ends for the 2005-2009 Mustangs. This unit replaces the factory IRS, with a housing that accepts any 9 Inch 3rd Member. Also, when using the stock brakes, you can retain use of the ABS Braking System.<br />
<u>Official Release:</u> <br />
<img src="http://www.stangtv.com/forum/attachments/2541d1255619465-currie-9-inch-rear-end-05-ce7015.jpg" border="0" alt="" /><br />
100% new 9-Plus heavy duty housing built to stock '05 and newer Mustang specs. Features include late model large bearing housing ends modified for retention of ABS equipment, all factory Ford suspension brackets installed for a perfect fit and finish including the Currie exclusive Johnny Joint® upper control arm mount that accepts the stock or Currie Currectrac® upper control arm. See CE-7015A for ABS equipped axles for this rearend, and CE-7015B-C for caliper brackets to bolt your stock brakes back on. Any standard 9" 3rd. member will bolt into this rearend, and any ABCS brake kit will bolt up - but at this time, only the stock brakes will retain the ABS. Also see our full line of Currectrac® control arms for this vehicle.<ul><li> 9-Plus Heavy Duty Housing</li>
<li> 9-Plus Late Model Large Bearing Housing Ends</li>
<li> Jig Mounted Factory Brackets</li>
<li> Currie Performance Axles</li>
<li> Retains Factory Disc Brakes and all ABS Equipment</li>
</ul><br />
<u>Contact Information:</u><br />
<b>Currie Enterprises</b><br />
Phone: 714-528-6957<br />
Web: <a href="http://www.currieenterprises.com" target="_blank">www.currieenterprises.com</a></div>
</ul><br />
