Cylinder Leak Down Tester from Moroso
<div>Moroso has a new Cylinder Leak Down Tester for testing compression in any engine. This tool is handy when testing an engine for compression and to diagnose problems before engine disassembly.<br />
<u>Official Release:</u><br />
<b>Cylinder Leak Down Tester<br />
</b><br />
<img src="http://www.stangtv.com/forum/attachments/2508d1255369421-cylinder-leak-down-tester-moroso-998d1255127496-cylinder-leak-down-tester-moroso" border="0" alt="" /><br />
The high performance tool you’ll pass down from generation to generation! Moroso asked top engine builders and race teams to give their input during development of the Moroso cylinder leak down tester.<br />
The two biggest results—they immediately asked, “When can I buy one?” and thought of even more uses for this versatile product!<br />
The Moroso Cylinder Leak Down Tester is built from top of the line components. This precision instrument is calibrated for high accuracy and repeatability.<br />
The unit is housed in a stand-up black powder coated steel case to make taking readings easier and to protect the components themselves<br />
The unit comes with 14 mm adapter long, 14 mm and 18 mm adapters short, tapered plug adapter and whip lines.<br />
<ul><li>Housed in a stand-up black powder coated steel case.</li>
<li>Calibrated for high accuracy and repeatability.</li>
<li>Test Compression on your engine.</li>
</ul><br />
<u>Contact Information:</u><br />
Moroso<br />
1-203-458-0542<br />
<a href="http://www.moroso.com" target="_blank">www.moroso.com<br />
</a></div>
