Dual Pattern Throttle Bodies from Quick Fuel
<div>Quick Fuel Technology’s offers a new billet aluminum dual pattern throttle body that allows a carburetor to mount on standard 4150 or a large 4500-pattern intake manifold. <br />
<u>Official Release:</u><br />
<b>Quick Fuel Technology Dual Pattern Throttle Bodies</b><br />
<img src="http://www.stangtv.com/forum/attachments/2316d1252003776-dual-pattern-throttle-bodies-quick-fuel-link.jpg" border="0" alt="" /><br />
Quick Fuel Technology’s (QFT) Dual Pattern Throttle Bodies allow your carburetor to mount on both a standard 4150 or a large 4500-pattern intake manifold. These solid billet aluminum Dual Pattern Throttle Bodies are CNC machined to exacting tolerances and can be ordered with either 1-11/16-inch (#12-755) or 1-3/4-inch (#12-854) stainless steel throttle plates to best fit your carburetion needs.<br />
QFT hand builds its Dual Pattern Throttle Bodies "slabbed" throttle shafts (machined away for more flow) and Teflon ribbon bearings for durability and superior sealing. The throttle plates are secured with low profile Torx plate screws to help reduce air turbulence. These throttle bodies feature a unique adjustable secondary pump cam bracket that allows for secondary airflow adjustment. The QFT spacer plate (#300-4145-1AL) offers a smooth transition and is required for use on the large flange 4500-style intakes.<br />
Each throttle body comes with an assortment of throttle links to easily change the opening ratio from soft progressive to medium progressive or 1:1. All attaching screws and gaskets are included.<br />
<ul><li>Solid billet aluminum and CNC machined.</li>
<li>Ordered with either 1-11/16-inch or 1-3/4-inch stainless steel throttle plates.</li>
<li>Secondary pump cam bracket that allows for secondary airflow adjustment.</li>
</ul><br />
<u>Contact Information:</u><br />
<b>Quick Fuel Technology</b><br />
1-270-793-0900. <br />
<a href="http://www.quickfueltechnology.com" target="_blank">www.quickfueltechnology.com</a></div>
Lordgufi
carb would have the throttle cables on the carb... looks like this is to do mebbe a sheet metal intake elbow?
