<div>Mechanical water pumps work well for a lot of people, but the problem is that they are belt driven and rob horsepower. Also, being able to turn on your water pump after a run helps reduce the temperature of the coolant faster than just letting it sit. Davies Craig has designed an external water pump that will work on virtually any application.<br />
The EWP 115 is available in plastic or lightweight aluminum and is designed to replace your mechanical unit. The turbo-like construction fits up between your radiator hoses with a simple slice. <br />
<img src="http://www.streetlegaltv.com/photos/data/703/IMG_1484.JPG" border="0" alt="" /> <br />
<embed src="http://www.powertvonline.com/xp2/dmlkZW8uc3Rhbmd0di5jb20/11494/1068/on/UA-459167-10" type="application/x-shockwave-flash" width="430" height="343"></embed> <br />
<img src="http://www.streetlegaltv.com/photos/data/703/IMG_1482.JPG" border="0" alt="" /> <br />
Davies Craig also has a universal electric fan switch that is thermostatically controlled. Their are five preset temperatures to select and then the controller can turn on both your fans and water pump when it reaches the required temperature. <br />
Check out more at <a href="http://www.daviescraig.com.au" target="_blank">www.daviescraig.com.au</a><br />
<img src="http://www.streetlegaltv.com/photos/data/703/IMG_14851.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/703/IMG_1488.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/703/IMG_14871.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/703/IMG_14812.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/703/IMG_14861.JPG" border="0" alt="" /></div>
