Emissions delete began yesterday since my smog pump froze up. So far I have removed the two smog control valves, smog pump and capped off the lines from the exhaust and the heads. Then I plugged the vacuum lines pulled from the control valves. I'm not researching all the vacuum lines that attached to the smog solenoids. I'll begin pulling them next and start capping of more lines until I find a common vacuum source. Then I'll kill them all with one plug. The Prochamber (o/r pipe) smog line was crimped and welded shut today at my shop. Hope to have it all completed by Saturday for the Dyno. I'm hoping for as much as 25HP with all the changes.
If you're smogging EVERY year, you're getting raped. Should be every OTHER year and for new cars, NO TESTS in the first five years, maybe six depending on whether you bought it in an odd or even numbered year.
