F/S 306 shortblock w/ low compression pistons
Sinful
I just got this shortblock with the intentions to build an N/A combo. However the pistons are low compression and it's not going to work out after checking them with my heads etc.
The shortblock looks fresh or has very low miles and you can still see the crosshatch on the cyl walls. I'm not sure who built it, it was purchased locally from a corral member but it was def done professionally. When I took out the pan, the left over oil looked pretty clean and no worn material. And also the oil filter looked pretty clean too and no obvious signs of worn material like bearings etc.
The shortblock includes the following:
-Low compression pistons +22.00cc D cup crown design (I believe they are KB
pistons)
-shortblock is bored .030 over, all freezes plugs, everything ready, painted and looks like it was zero decked.
-dog bones and spyder
-Timing chain and gear
-Stock resized rods with ARP studs
-Stock crankshaft
-Oil pump, pickup and distributor shaft
-Oil pan tapped for oil return line for your turbo/supercharger
-Oil pan studs w/ nuts
-50oz balancer
$500
Leave your email for pictures
