F/S Cam and lifter kit NIB
eleetryder
Leet WS Member
Still have this from a previous ad.
I am selling a cam and lifter kit BNIB. I got it when I got received my heads. Its just sitting in my garage. PM me if your interested. A steal at $100
SB Ford 289 - 302ci Magnum Camshaft CL Kit# CL31-414-3. HYDRAULIC: Performance use.
Sells for $185 new from Summit Racing plus shipping
http://www.summitracing.com/parts/CCA-CL31-414-3/
Info from Summit:
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,800-5,800
Intake Duration at 050 inch Lift 224
Exhaust Duration at 050 inch Lift 224
Duration at 050 inch Lift 224 int./224 exh.
Advertised Intake Duration 270
Advertised Exhaust Duration 270
Advertised Duration 270 int./270 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.500 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.500 in.
Valve Lift with Factory Rocker Arm Ratio 0.500 int./0.500 exh. lift
Lobe Separation (degrees) 110
Intake Valve Lash 0.000 in.
Exhaust Valve Lash 0.000 in.
Grind Number FS 270H-10
Computer-Controlled Compatible No
Lifters Included Yes
Lifter Style Hydraulic flat tappet
Valve Springs Included No
Retainers Included No
Locks Included No
Valve Stem Seals Included No
Timing Chain and Gears Included No
Assembly Lubricant Included Yes
Pushrods Included No
Rocker Arms Included No
Gaskets Included No
