These heavy duty Ford Racing 31 spline axle shafts are designed to replace your OEM weaker axle shafts. Axle shafts are an often overlooked area of a Mustang drivetrain, and are actually one of the weakest components in the entire drivetrain. If you drag race, run slicks, or have a higher horsepower Mustang, replacing your stock axles will give you more piece of mind. The 31 spline axle shafts require a 31 spline differential or axle assembly.
These heavy duty Ford Racing 31 spline axle shafts are designed to replace your OEM weaker axle shafts. Axle shafts are an often overlooked area of a Mustang drivetrain, and are actually one of the weakest components in the entire drivetrain. If you drag race, run slicks, or have a higher horsepower Mustang, replacing your stock axles will give you more piece of mind. The 31 spline axle shafts require a 31 spline differential or axle assembly.Click Here / Parts added daily...
