Lakewood Industries Shocks for Street/Strip Applications
<div>Lakewood Industries has a drag shock for guys running on the street or the strip. The shocks come in fixed ratios of 90/10, 70/30 and 50/50. The valve design on these shocks gives the you the ability to get an excellent starting line reaction and a stable high speed operation. They also have a longer extension length compared to the stock shocks to aid in proper body separation at launch.<br />
<u>Official Release</u><br />
<b>SHOCK TREATMENT FOR THE STREET OR STRIP</b><br />
<img src="http://www.stangtv.com/forum/attachments/2919d1262884503-lakewood-industries-shocks-street-strip-applications-attachment-09-12-04.jpg" border="0" alt="" /><br />
Lakewood Industries, the leader in traction and suspension products, has combined it’s experience with the latest technology in drag shock design to develop a shock absorber in true, non adjustable, fixed ratios of 90/10, 70/30, ad 50/50. The Lakewood Drag Shock has performance characteristics superior to any other shock on the market today.<br />
• State of the art Valve design for excellent starting line reaction and stable high speed operation like no other shock on the market today<br />
• O.E. quality rubber bushings provide consistent performance, long life and isolation from track irregularities.<br />
• Chrome plated piston rod to prevent corrosion that would cause premature seal wear.<br />
• No dust covers on shocks for weight reduction and to monitor usable shock travel.<br />
• Rubber travel indicator on rear shocks allows you to measure rear movement on initial launch<br />
• Specially formulated hydraulic fluid for precise and consistent drag strip operation regardless of temperature<br />
• Longer extension length than stock to aid in proper body separation on initial launch<br />
• Over extension and compression is internally controlled with hydraulics instead of “OEM” style urethane stops. If over extension or compression does occur , impact will be “cushioned” to prevent any damage to the shock while giving the driver added control<br />
Designed to mount in stock location without modification.<br />
<u>Contact Information</u><br />
<b>Lakewood Industries</b><br />
Phone: 216-688-8300<br />
Web: <a href="http://www.lakewoodindustries.com" target="_blank">www.lakewoodindustries.com</a></div>
