<div>Our friends at MAHLE rolled out a complete line of PowerPak Piston Kits that are designed for more power, more performance and better results from your engine. According to Trey McFarland of MAHLE, the secret is in the MS124 aluminum alloy used in the manufacturing of the pistons. Trey also explained how the ring grooves in the pistons are ultra flat and de-burred at the factory. The pistons skirts are dual coated with gray phosphate coating for less friction and low drag.<br />
<img src="http://www.streetlegaltv.com/photos/data/500/IMG_38231.JPG" border="0" alt="" /> <br />
MAHLE's PowerPak Piston Kits are available for Big Block Chevy, GM L92, LS7, Ford Big Block, Ford Cleveland, Small Block Mopar, Big Block Pontiac, Big Block Olds, and several imports. <br />
Highlights of the MAHLE PowerPak Piston Kits:<br />
<ul><li>All forged pistons</li>
<li>Manufactured from MS124 aluminum alloy</li>
<li>Pistons designed with ultra flat ring grooves</li>
<li>De-burred at the factory</li>
<li>Ready to drop-in with only minimal ring filing required</li>
<li>Dual coated with a gray phosphate coating that prevents ring microwelding and pin galling. Plus GRAFAL, a proprietary MAHLE coating that cushions the piston skirt at rock over and reduces drag</li>
<li>The MAHLE PowerPak comes complete with low drag ultra-flat MAHLE rings, high grade German steel pins and F1 inspired round wire locks.</li>
</ul><br />
For more information visit MAHLE at <a href="http://www.mahlemotorsports.com" target="_blank">www.mahlemotorsports.com</a> <br />
<img src="http://www.streetlegaltv.com/photos/data/500/LS7_PowerPak.jpg" border="0" alt="" /></div>
</ul><br />
