Some of you guys asked about my fox build in my cobra thread.Well here it is.
Stats
9 to 1 347
svo r block
620 roller cam nx282hr comp stick,fms lifters
cncd afr heads
vic jr efi intake
basani long tubes
f1r blower on 10psi
alky control water meth kit
91 pump piss fuel
huge fuel system A1000 pump aero motive rails and regulator,-10 line
big air to air inner cooler
custom steve spurrier charge piping cermi coated by caps
trans tko 600 trans 5spd
billet steel flywheel
south bend clutch
stock driveshaft
built 3.73 rear end
big brakes,floating 15 inch frt rotors baer calipers green stuff pads
full griggs suspension.Tq Arm panhard bar setup,coil overs all 4 corners 450lbs frt springs 380lbs rears,who wants to go turn in the twistys.
interior
all new carpet has 03 cobra seats, all re cleaned
new interior panels
center console delete
new alpine cd/mp3 deck
custom built by kicker amp rack speaker /batt/meth storage box
I also installed a full set of cobalt guages
im sure im missing a bunch of stuff as i have changed so much on it.
Ive pretty much disassembled the whole car,fixed and cleaned up some stuff,repaired some wiring,updated the aem stand alone.Jay put together a very nice peace,i put some of my touchs to it and just went over the car with a fine tooth comb.Im hoping to have it out next weekend.Coming to a freeway near you looking for 1 liters to play with!!!
Here are some cell phone pics.
Ive changed some stuff,went from efi to blow thru.car will be road ready this weekend.should make 600 or so on pump gas on 10psi.
The car made 640 whp on just under 10psi at 7000 rpm on 91 octane fuel.Will turn meth on and maybe get 680 ish.
And alittle update on my cobra,i went to a powerglide trans,its almost done,heading to the track on the 16th of the new year.Spark blowout resolved and if anyone needs to know the fix ive got it for all 99 to 04 fords cars and trucks.And it flat works.
Hope you like my fox.
Stats
9 to 1 347
svo r block
cncd afr heads
vic jr efi intake
basani long tubes
f1r blower on 10psi
91 pump piss fuel
south bend clutch
stock driveshaft
built 3.73 rear end
interior
new interior panels
