New Upper Control Arms Installed
Well installing the control arms was very easy, but I had to destroy my UPR solid spherical bushings to remove them. I did modify this kit for ease of adjustment I drilled out a 3/4" nut and slid it over the control arms and then welded the nuts to the arms. I couldn't see putting a pipe wrench on new parts.
Thanks to PapaTom for coming over and helping me get everything installed.........twice, lol!
The point of this install was to fix the poor geometry / location of the upper control arms. The kit raises the rear upper control arm mounting point and moves the car's "instant center" back toward the rear of the car in order to hit the tires harder.
Well enough blab here's the kit installed.
just when i thought you were done screwing with you suspension...the car will be leaving with the wheels up higher and some GTO's in the dust...lol
That does look like it would do something. Hope it helps ya launch. Will you be ready by this sunday?
It's ready. If it doesn't hook I'll have to make adjustments on the fly. I'm hoping to get deeper into the 1.4's in the 60' and stay there. Currently I cut low 1.5's with the occassional 1.49-1.48.
