Professional Products FuelOnDemand & Stage 4 EMS
<div>While at SEMA this year we also saw Professional Products' new FuelOnDemand fuel controller. This is the same technology offered in their Stage 4 EMS and Powerjection+Plus systems. This all in one fuel module is capable of controlling the fuel for carburetors, EFI return style and EFI returnless systems. <br />
- Built In 2.5 BAR MAP Sensor<br />
- Weather Proof Design<br />
- Comes With Fuel Sensor, Harness and Module<br />
<b>Check out the Video Feature we shot on the FuelOnDemand</b><br />
<embed src="http://www.powertvonline.com/xp2/dmlkZW8uc3Rhbmd0di5jb20/11078/1068/on/UA-459167-10" type="application/x-shockwave-flash" width="430" height="343"></embed><br />
<b>Stage 4 EMS</b><br />
Professional Products was showing off some new additions to their product line up. The Powerjection Stage 4 Engine Management System is a full feature EFI with fuel, spark and fuel pump control all in one. It also features an Adaptive Learning feature that fine tunes the fuel map to best fit the needs and requirements of the engine. The timing control feature replaces the ignition box on your vehicle and fires the coil itself.<br />
<img src="http://www.streetlegaltv.com/photos/data/690/IMG_6638.JPG" border="0" alt="" /><br />
The build in FuelOnDemand feature controls the speed of the fuel pump and varies it depending on the demands of the engine. It is able to read what your engine needs by using a wideband O2 sensor and 2.5BAR MAP sensor.<br />
- Controls Fuel, Spark and Fuel Pump<br />
- Replaces Ignition Box<br />
- Build In FuelOnDemand<br />
- Includes Wide Band O2 Sensor ad 2.5BAR MAP Sensor<br />
- Works Under Up To 25 PSI of Boost<br />
- Features Adaptive Learning<br />
You can find more by visiting <a href="http://www.professional-products.com" target="_blank">www.professional-products.com</a>.</div>
