Quick Fuel Series Hot Rod Carburetors
<div>Quick Fuel, who is well known for their lines of race series carburetors, is now launching a line of street carbs appropriately called, Series Hot Rod. The new line take directly after their race-application big brothers, but are offered in a cast design to make them more affordable. Offered in both vacuum and mechanical secondary models, all the carburetors offered in this line have changeable air bleeds and high speed adjustment so you can really dial the fuel delivery to match exactly what your engine needs. On the outside, the finish is the result of a tumble polish that leaves the exterior with a shine that both looks good and won’t fade away. <br />
<img src="http://www.streetlegaltv.com/photos/data/703/IMG_8471.JPG" border="0" alt="" /><br />
There are a total of six different CFM options, three for vacuum secondary, and three for mechanical secondary models - with most featuring down leg boosters. You also get aluminum fuel bowls with sight glasses and four corner idle system no matter which size you choose. <br />
<img src="http://www.streetlegaltv.com/photos/data/703/IMG_84761.JPG" border="0" alt="" /><br />
• Vacuum Secondary CFM Options: 580, 680 & 780<br />
• Mechanical Secondary CFM Options: 650, 750 & 850<br />
• QFT QuickSet Adjustable Secondary Vacuum Housing on Vacuum Version<br />
• Aluminum Fuel Bowls with Sight Glass Window<br />
• Four Corner Idle System<br />
• Down Leg Boosters On All Versions Except Vacuum Controlled 580 CFM & Mechanically Controlled 650 CFM<br />
• Electric Choke<br />
• Changeable Air Bleeds<br />
• Tuneable Secondary Linkage<br />
For more on these new carbs, check out <a href="http://www.quickfueltechnology.com" target="_blank">www.quickfueltechnology.com</a>.<br />
<img src="http://www.streetlegaltv.com/photos/data/703/IMG_8477.JPG" border="0" alt="" /><br />
<img src="http://www.streetlegaltv.com/photos/data/703/IMG_84781.JPG" border="0" alt="" /></div>
