Selling my 07 and my fox
elky406
The 07 has 58k on it,has bassani long tubes,stock h pipe and muffs,built rear end with 4.10s and a girdle cover.Steeda pulleys,steeda 1 pcs drive shaft,steeda upper and lower rear control arms,charge delete plates,gt500 wheels and tires with about 1500 miles on them,gt500 hood,jlt intake,new hto plugs,nx nitrous plate kit,nos bottle warmer,sct xcal2 programmer,mgw shifter,new zero mile take out trans with about 3500 miles now,new clutc with new slave assembly.
car makes 322 whp 337wtq on motor
466whp and 540wtq on a 125 shot.
body is very nice,interior has one little snag in rear seat.
car has gone a best of 12.70 at 111 on motor and 11.56 at 123 on bottle.
I will post pics after i get it back from detail next week.
18,000 obo
My fox
79 notch chassis,with 88 and up body panels,clear lights and corners,nice silver paint,straight body.
motor
8.5 to 1 347
probe rotating assembly
girdled
comp custom ground nitrous cam
comp pushrods and lifters
comp double springs
cloyes double roller chain
comp retainers
stainless valves
epw roller rockers
pro comp heads
felpro mls head gaskets
eddy performer rpm intake
fms valve covers
makes 322 threw a c4 on motor
490whp on a 150 shot
Trans
redneck loaded c4 with brake
b and m 2800 converter
big trans cooler
Nitrous system
nos cheater
purge
nos bottle warmer
-6 feed line
nitrous arming wired threw a latching trans brake relay
Fuel system
-8 feed line
fuel cell
two holley blue pumps
two summit billet regulators
all blue push lock fuel line
bg 750 double pumper carb
k and n 14 inch air filter
suspension
lakewood shocks all the way around
moroso springs front and rear
sub frame connectors
built rear end,axles,3.73s,girdle,new posi
cooling system
28 inch wide aluminum radiator
dual fans
ignition
msd digital6 box
msd pro billet dist
msd coil
fms wires
wheels and tires
weld pro star 3.5 skinnys and new tires
weld prostar 15x8 with hoosier 27x11.50 quik time pro
5 lug conversion
this car has gone 11.88 at 117 at sac on motor and 10.20 at 135 on bottle
7k turn key as it sits.
I believe that this car with a vic jr and 200 pills will go 9s
elky406
elky406
Ya its a decent little car,had a cam and tune,tune was not so good with 25% lean fuel trims,so got most of that figured out,car seems to run pretty well.gotta fix,ac and window motors.
elky406
yes we need something bigger so cars can stay inside.
We found the shop,and we will start moving soon.
