<div>Many car builders are familiar with Stainless Steel Brake Company, but today we saw that they are going to be offering more than just street car brakes - in fact even more than brakes!<br />
<img src="http://www.streetlegaltv.com/photos/data/692/IMG_62671.JPG" border="0" alt="" /> <br />
First up was the new Competition Brake Series. This light weight braking system is designed for drag racing and is being offered for popular GM, Ford and Mopar vehicles. These new calipers are being packaged in a number of different kits; everything from someone looking for just calipers, to a complete brake system replacement. SSBC now has these calipers available for both front and rear applications. But if your rotors are in need of replacement, SSBC has rotors designed to work with these calipers.<br />
<img src="http://www.streetlegaltv.com/photos/data/692/IMG_62631.JPG" border="0" alt="" /> <br />
- Theses are offered in both street and race versions<br />
- Works with almost any rotor<br />
- Designed for drag racing<br />
Also on hand was SSBC’s new TMAX Transmission Thermostat. Designed to increase in the efficiency of your transmission, this universal kit comes with everything needed for installation and requires no special tools to install. What it does, is work with any automatic transmission and any transmission oil cooler. When the fluid is cold, it re-routes the fluid back into the transmission instead of the cooler, keeping your fluid at an optimal 190 degrees. SSBC claims that this will increase both your MPG and transmission life.<br />
- Increase Transmission Life<br />
- Keep Your Transmission At The Right Tempature<br />
- Increase You MPG <br />
Head on over to <a href="http://www.ssbrakes.com" target="_blank">www.ssbrakes.com</a> for more info.<br />
<img src="http://www.streetlegaltv.com/photos/data/692/IMG_62703.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/692/IMG_62621.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/692/IMG_62692.JPG" border="0" alt="" /></div>
