The Steeda heavy duty belt tensioner will help eliminate the bending of your OEM tensioner, which can cause accessory damage and belt breakage. This problem is most apparent after installing an aftermarket supercharger. The supercharger puts much more strain on the belt and other accessories, as well as the tensioner itself. The OEM tensioner tends to bend under this unwanted stress, but can easily be fixed with the Steeda heavy duty tensioner. The Steeda tensioner will save you time and money by improving the relability of your supercharged engine, and will prevent you from having to replace belts and tensioners.
The Steeda heavy duty belt tensioner will help eliminate the bending of your OEM tensioner, which can cause accessory damage and belt breakage. This problem is most apparent after installing an aftermarket supercharger. The supercharger puts much more strain on the belt and other accessories, as well as the tensioner itself. The OEM tensioner tends to bend under this unwanted stress, but can easily be fixed with the Steeda heavy duty tensioner. The Steeda tensioner will save you time and money by improving the relability of your supercharged engine, and will prevent you from having to replace belts and tensioners.Click Here / Parts added daily...
