Steeda Tri-Ax® Shifter for Tremec 3550 & TKOOffset-Preload" coil springs find third gear for you so you won't miss! Most comfortable hand position of any short throw shifter Two position adjustable height Shortest throw of any shifter Smooth, confident, precise shifts Exclusive BootGuard (prevents damage to factory rubber inner boot) Adjustable positive stops prevent over extending the shift lever, preventing costly transmission damage Compact tower design is easier to install CNC machined from billet 6061 T-6 aluminum Heavy duty construction No welds, stampings, or castings to break Nickel plated pivot shaft won't rust or stain Grade 8 and stainless steel hardware Made in the USA Accepts factory & Steeda knobs Includes Steeda's exclusive Tri-Ax shift handle Fits Vehicle Model:Ford with Tremec 3550 or TKO transmission
More...
More...
