Steeda Upper Control Arm
Does anyone have any experience with the Steeda adjustable upper control arm on a 2013+ GT? I plan on adding the Eibach pro-kit springs and Steeda LCA's. Just wondering if I have to change out the UCA and if so how bad the NVH is with the Steeda UCA.
Thanks,
Bill
tom
Call Eibach, I am doing the pro-kit also and BMR UCA and LCA's . Check your pinion angle if you do the UCA . Danny put the same springs kit on his 13 gt as yours with no UCA with no problems. Good Luck
As Tom said I put the springs on my '14 GT. I did not put LCA or UCA on. I may later but as of now I didn't see a need. All I did was get an alignment and the car drives fine.
Ok thanks. It may a dumb question, but how do you check the pinion angle? Danny, when you changed the springs did you also add an adjustable panhard bar?
I don't know how to check the pinion angle, but I would take it to an alignment shop, they would be able to check it. I did not change my panhard bar.
