Up to Eight Stages of Nitrous Timing from Spaghetti Menders
<div>If you are looking for a more sophisticated way to time your nitrous activation, then look no further than Spaghetti Menders. While being well known for their simple yet functional race car wiring systems, they have also produced nitrous timers. This is their new upgrade over the Digi-Set version (though they still do offer those).<br />
<img src="http://www.streetlegaltv.com/photos/data/705/IMG_16461.JPG" border="0" alt="" /><br />
<embed src="http://www.powertvonline.com/xp2/dmlkZW8uc3Rhbmd0di5jb20/11569/1068/on/UA-459167-10" type="application/x-shockwave-flash" width="430" height="343"></embed> <br />
The timers are offered in 1 stage, 2 stage (with 2+1), three stage, four stage, and a monstrous eight stage. The stages can be adjusted in 1/100th, 1/10th, and one second intervals. While the majority will switch stages between the selected time, the 2+1 stage kit will allow you to first activate the first stage, the second, and then the first stage again together with the first. Therefor you could run a 100 shot first stage, 200 shot second stage, and your third stage would be a combination of both at a 300 shot.<br />
<img src="http://www.streetlegaltv.com/photos/data/705/IMG_1644.JPG" border="0" alt="" /> <br />
Depending on what system you get, there is a combination of line and motor purges throughout. There are also two options for pedaling the car: first the timer will restart from the same spot before you lifted and the second is a hold function that will stop the nitrous activation completely if you lift and get back into the throttle.<br />
Check out more on their systems at <a href="http://www.racewiring.com" target="_blank">www.racewiring.com</a><br />
<img src="http://www.streetlegaltv.com/photos/data/705/IMG_16412.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/705/IMG_16402.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/705/IMG_16471.JPG" border="0" alt="" /> <br />
<img src="http://www.streetlegaltv.com/photos/data/705/IMG_16431.JPG" border="0" alt="" /></div>
