Put the connector in the spot where your windshield wiper is. That should do the trick.
If you add timing the fuel will lean out and you will gain power and torque. The whole reason for running higher octane fuels and Meth is so you can get more timing without pre-ignition/detonation. Adding timing is where you get your power from..
Add 1* at a time and see how the air fuel reacts. Never get greedy and add more than 1* before seeing what the a/f is doing cool?
alright then, i think this week i'll try and mess with it to get her dialed in, what do you think is the best a/f range 11.8 11.9....
