5.0 parts for sale
0ne_sik_notch
I am posting this for a friend and here is a list of what I he posted for sale. It's updated other than I he has most of an original Black GT interior(minus dash, headliner, carpet, and console). Let him know if any of this stuff interests you. It's a big list. Thanks, philz1970@aol.com
PERFORMANCE PARTS:
Ford Racing/Crane Cams 1.6 roller rockers. Pedestal mount. Good shape. $135.00 for the set
Autometer 5 1/4 Tachometer with shift light. Great shape, almost new. Goes to 10k rpm. All black housing with black face. $100.00
Complete 8.8 drag built rearend. Ford Racing 4.10 gears with Auburn 31 spline posi. Tom's KA axles 4 lug 31 spline. New urethane diff bushings. Moroso long wheel studs. Less than 1k miles on the internals. $400.00 Also includes a set of V-8 front 4 lug rotors with NEW Moroso long studs.
Complete 8.8 rearend with Motive Gears 3.73's and another complete 8.8 with Ford Racing 3.73's. Stock posi's in both. Motive Gears rearend has about 30k miles on it and the Ford Racing rearend has about 50k miles on it. Good shape on both. Complete drum to drum including e-brake cables. 4 lug. $250.00 each
UPR Pro series adjustable lower control arms. Brand new heim joints. Solid mounting. NOT for a street car. Has coil spring mounts. $100.00
Lakewood 90/10 front drag struts and lakewood 50/50 rears. Older, but have less than 1k miles on them. $175.00 for all, WILL NOT SPLIT UP!
Moroso rear drag launch springs. REARS ONLY. Less than 1k miles on them. $65.00 for the pair
BBK specific rate lowering springs. 1.5 inch drop. Great shape. Less than 10k miles on them. New these sell for over $200.00. Buy these that are near new for $100.00.
BBK rear coilspring urethane isolators. A must when swapping springs. These are brand new in the package. Paid $30.00, sell for $25.00
UPR billet aluminum caster camber plates for '87-'89 Mustangs. Brand new, just mounted but never run. These are the strongest out there. New they are $190.00 plus shipping. I'll sell them for $150.00. Again, these are near new.
Hotchkis Caster Camber plates. Aluminum. Great shape. $100.00.***PENDING SALE!!!***
KONI orange struts and shocks(non adjustable). Good shape, about 30k miles on them. Also included are some KYB Gas-A_Just quad shocks for the rear. $175.00 for all. Will NOT split up!!!
Pro Products Typhoon intake manifolds. 1 in polished chrome, the other in Satin silver finish. Same as the Edelbrock RPM intake. $250.00 for the satin one and $300.00 for the polished one.
Explorer GT-40 intake manifold. Upper and lower. Complete with heater tube, stock 19lb injectors, fuel rail, and stock throttlebody. All for $175.00
Pro Products 65mm throttlebody and spacer. Almost new condition. Comes with all sensors and EGR valve for $110.00
BBK 70mm throttlebody and spacer. Good shape. $135.00
Ford Racing 65mm throttlebody. Good working shape. Has TPS sensor and IAC valve. No spacer. $50.00 for all.
MAC equal legnth headers with bolts. Great shape. $100.00
BBK high flow catted h-pipe. Less than 1k miles on it. Needs 2 clamps, otherwise complete. Still have the original box. New these are $400.00. Buy this one for $250.00
Dynomax Mufflers. Good shape. Bolt onto any h or x pipe. Comes with GT tailpipes. $85.00 for the pair.(Flowmasters used for a file photo)
Ford Racing 24lb injectors. All 8 in good shape. Came off a running 5.0. $40.00 for the set
BBK adjustable fuel pressure regulator. Bought used as a spare. Good shape, no leaks. $50.00.
Kirban adjustable fuel pressure regulator. Good shape. Less than 1 year old. Off a running 5.0. $50.00
K&N panel filter. Fits stock airbox. Good shape. Just been cleaned. $10.00
C&L 76mm mass air housing with sensor. Great shape. $100.00 or $80.00 without sensor.
Used Ford Racing King Cobra clutch. About 10k miles on it. With flywheel and bolts. $75.00***PENDING SALE!!!***
MSD 6A ignition box. Working shape. $85.00
Aftermarket aluminum radiator and Proform electric fan. These are both less than 1 year old. Good shape. No leaks or damage. $125.00 for both.
Ford Racing high flow water pump for '79-'93 5.0's. Brand new in the box. $60.00
Mass air computer. 8LD out of an '88 GT 5 speed and an A9M out of a '93 GT 5 speed. $100.00 ea FIRM. Also have mass air sensors($40.00), map sensors($30.00), and harnesses($40.00) for a complete mass air swap. Will do a package deal for a complete swap with computer for $185.00
TRANSMISSION:
T-5 swap. Includes: Transmission, bellhousing, starter, pedal assembly, driveshaft, and crossmember. No shifter, clutch, flywheel, or clutch cable. Out of an '89 GT convertible with 140k miles. Trans shifts good with no issues. $400.00 for everything. Will NOT sell anything separate.
AOD out of a 105K mile '90 LX. The trans was swapped for a 5 speed. Worked when it was pulled, but that was about 1 1/2 years ago. Been in garage storage. Comes with converter, shifter, crossmember, and trans cooler lines. $100.00
RIMS:
Original '93 Cobra rims. I ONLY have 3 of them!!. 2 left sides, 1 right side. All caps incuded. This is no BS, these have the original Ford part #'s on them. The silver finish does need to be redone. Not perfect, but very presentable. $250.00 for all 3. Will trade for a full set of 4 repro '93 Cobra wheels. I can add some cash on my part for the right trade. NOT interested in any other wheel trades!! Thanks.
Silver Pony wheels and tires. Great shape. No rash. Refinished in the original silver. Tires are Nexen 225/55/16's. 2 have 80% tread, the other 2 have 60% tread. $300.00
Rare aluminum spares. Great to use as drag skinnys up front. 2 available. ($50.00 ea or $75.00 for a pair)
INTERIOR PARTS:
Red upper console section. Ashtray door intact but doesn't work. $15.00
Red door panels armrests and also a set of red kick panels. All in good shape. $5.00 each
Rear grey sport seats out of a '90 GT hatch. Nice shape. $25.00
Grey dash complete with pad and all vents. Glove box lid also included. $40.00
Grey console. Complete upper and lower sections. Nice shape. $40.00
Grey console armrests. 2 to choose from. 1 in fair shape for $25.00. Pad is good. 1 in mint shape, very nice pad and solid base. $50.00
'87-'93 headliner trim/a pillars. All in great shape. All 6 pieces of trim. ($5.00 ea or $20.00 for all)
'90-'92 Grey seatbelts. These are just the front pair. Both work great. Fits hatchbacks and coupes. ($20.00)
'86-'89 Grey seatbelts. These are also just the front pair. These work great to. Fits hatchbacks and coupes. ($20.00)
'93 OPAL grey seatbelts. Fronts and rears. $40.00 for all
'79-'93 Grey door sill plates. Nice, not broken. ($15.00 for the pair)
'87-'93 Grey kick panels. Good shape. ($10.00 for both)
'93 OPAL grey dash pad center a/c vents. This is not the complete dash, just the center padded part with the vents. Really nice shape. ($40.00)
'87-'93 Heater controls. Working shape. ($25.00)
BODY PARTS:
Coupe/notch 1/4 glass. Rubber is 8.5 out of 10. Great shape. No dissapointments. $200.00 for the pair.
Convertible trunklid with '92 Feature car spoiler. Nice shape. Swap out that ugly luggage rack. Only sold together, will not sell just the spoiler. $75.00
LX taillights. 1 set with housings(right side is mint, left side is faded). $40.00 for this set. Also have a really clean set with no damage for $65.00
GT "cheesegrater" taillights. These are dark blue in color. Great shaoe with no cracks. Housings are included. $50.00 for the pair
'87-'93 headlight lenses. These are aftermarket with VERY little yellowing. Good shape. $35.00 for the pair. I also have an original FORD drivers side headlight in great shape, no yellowing at all for $30.00
1/4 glass for '87-'93 Coupe/Notch. Fair condition. 7 out of 10. RIGHT SIDE ONLY. $20.00
GT rear bumper. Nice shape. Comes with the reinforcement. $50.00
LX doors. Manual windows. Nice shape. Come with manual mirrors and body side mouldings. Fits hatchback and coupe/notch. $25.00 each or $40.00 for both
GT front fender extensions. Needed for a GT conversion or aftermarket bumper swap. Specific to '87-'90. $30.00 for the pair. I also have an extra drivers side for $15.00
GT side skirts. All 4 pieces Nice shape.$10.00 ea or $25.00 for all
Tail light housings. These are what the lenses attatch too. Not broken. $10.00 per pair
GT rear hatch spoiler. Off a '93 GT. In primer. Comes with the 3rd brakelight. $30.00.
GT hatch with wing. 1 small rust bubble near the glass mouldings. $40.00 for all.
Nice LX passenger side fender. Fits '87-'90. Clean, no dents or rust. $20.00
Side mirrors for '87-'93. Power ones for hardtop and convertible, and manual mirrors for a hardtop. $15.00 each or $25.00 per pair
Fender liners(the black plastics that go behind the tire). Left and right sides. Not broken or cracked. $5.00 ea.
Wiper cowl panel plastic grille. Good shape. Not broken. ($35.00)
Rear hatchback glass. Has provisions for rear defroster. ($20.00)
Rear backglass for a coupe/notch. Has a rear deforoster. $30.00
2 stock hoods. Nice shape. 1 in dark blue and one in black. Paint is no good on either hood. $50.00 each
Complete front radiator core support. Cut off right in front of the strut tower. Very straight. Fix your messed up support. I have 1 for '79-'89 cars and 1 for '90-'93's. The hood latch and all the airbag sensors are on the one for the '90-'93's. $75.00 each
ENGINE/UNDERHOOD PARTS
'86-'93 5.0 radiator fan shroud . Great shape. Shroud is not cracked or broken. ($35.00)
Complete A/C system for '85-'93 5.0. Working compressor, lines,hoses, and condenser, etc. ($75.00 for everything)
Stock airbox. Not cracked or broken. ($15.00)
Ignition coils, distributors, starters,alternators, etc starting at $5.00 ea
I want the water pump. Let me know how to make this happen!!!
0ne_sik_notch
email him and im trying to get a door and fender from him, maybe we can car pool lol or he lives near papatom in sun city
I'll have Tom pick it up for me....LOL. I have to drive to Temecula to pick up my supercharger. I'll just keep on driving...LOL
Tommy
If this is the same guy I spoke to last week, Phil-who works in a parts dept for a dealer, I want the following if he takes Paypal. I'll cover the fees, and of course....if he makes me a package deal.
Grey console armrest. 1 in mint shape, very nice pad and solid base. $50.00
0ne_sik_notch
email him phil1970@aol.com
Tommy
I have his #
I'll call him later. I might just have to drive there with an empty truck bed!!! :rofl:
0ne_sik_notch
i need a drivers door and i have cash in hand for it but i cant get the time to drive up there hook me up and ill give you a lil on top of what you payed but the door has to be perfect
navyfc117
I bought the following from him ijn the last couple weeks.
Taylor Battery Relocation Kit
#30 FRPP Injectors
Granatelli MAF
Aluminum Radiator and Pro Form Fan
He is shipping the parts to my apartment.
navyfc117
I still havent recieved my parts from this guy yet? He said he was going to ship them on monday?
navyfc117
I recieved half of them. Still waiting on the rad and fan. The injectors, MAF, and battery box all looked good according to the wife. I will probably pick up some more stuff from him after this next pay day. I think i want the ignition box he has.
