5.0 to 4.6 L Conversion
All, this is going to be a fun project.. So I ask if you guys can go out and get all the information possible to complete this project.. (Check fourms, friends whatever)
Parts List for the Conversion:
AJE K-member
dope3
found this
I HAVE INSTALLED A 4.6L FROM A 98 MUSTANG INTO MY 88 LX. (WAS A 5.0) I HAD TO PURCHASE A AJE K-MEMBER WITH MOUNTS & I MODIFIED MY TRANS CROSSMEMBER TO FIT THE T-45 TRANS & SHORTED MY DRIVESHAFT (FRPP FOR A 96-98 MUSTANG) HAD TO SHORTEN .655" YOU WILL NOT NEED MOTOR MOUNTS IF U PURCHASE THE AJE K-MEMBER. I DID RUN INTO A PROBLEM WITH THE ANTI-THEFT FROM THE 98 MUSTANG ECM. i FIRST USED A JUMPER WIRE AT THE PCM TO SEND A SIGNAL. THEN I SENT MY ECM OUT & HAD IT PROGRAMMED SO IT DID NOT NEED IT, ALONG WITH HAVING IT TUNED.
good find dope3... That is the type of stuff we need...
Alright just contacted AJE Racing and there K-Member for the 4.6 to fit in a 5.0 is part number MU3020 - $349... We need to see what K-Member we have if its an AJE all we need is the mounts...:)
90stripes
i dont remember who said it, and i cant find the post but someone said that on the aje k member the motor mounts are already on it or something. bc it was made for this conversion... but i could be mistaken
This shouldn't be too tough of a project it will greatly benifit those that have never witnessed a swap like this one. The car should be a hit on the track.
I was looking up parts and specs last night on ebay and on google, i couldn't even find a cold air intake for this car. I haven't seen the engine but im sure some thing will fit it.
In the hot rod mag that CWO found, they used a K member for 96-04 mustang, i think if we were to come up short we could go to the junk yard and pick one for cheap.
I like the way you are thinking.. From what I have read too should be an fairly easy install... We will see.
I have read that the Cobra intake setup will bolt right in..
