ABS light !!!???? help.....
so after leaving JBA for the second time with in 45 min because they gave me the wrong tune on my hand held(pay a "professional" 95 bucks to call your cell phone once your half way down the road oh i made a mistake) i was on the 125 and the ABS light came one any ideas why this would happen? what can i do to fix it any ideas post back on here or hit me up on my cell 619-278-1581
disconnect the battery see if it goes away. Is one way. the only other way is a code reader like the OBD-II type but, for the ABS.
Try to disconect the batt. like Emilio said. If you have a hand held tuner you can read the codes and clear them. My wifes mini van brake light comes on when her brakes get warn dow to a certain level. Maybe you need to check them...
Roushed2
302 Motorsports
disconnecting the battery wont mess up the tune at all
But like I said just take out the light and it wont bother you any more LOL
Roushed2
302 Motorsports
if i see a check engine light on i get it scanned and if its noting major just disconnect the battery to erase the code
Roushed2
302 Motorsports
Auxilliary Emissions Control usually indicates your EVAP system. P1443 indicates incorrect EVAP system purge control valve flow. Possible cause may be damaged EVAP cannister purge solenoid or damaged purge flow (PF) sensor
