MM Rear Stainless Steel Brake Lines ? 94?95 5.0L Mustangs
Maximum Motorsports brake lines boldly represent MM's attention to detail, quality and the passionate pursuit of perfection. Teflon?lined, braided stainless steel hoses provide better performance than the stock rubber hoses with a firmer brake pedal, quicker braking response and better brake modulation. These hoses are considered a safety requirement for any car that is raced. The high heat generated during track use has been known to cause failure of the stock rubber hoses. Maximum Motorsports was the first to offer direct replacement stainless steel brake hoses for Mustangs over 10 years ago. Features: Direct fit bolt?on installation Teflon lined for extra strength and durability Stainless steel braiding, eliminates any flex Comes with banjo bolts (fluid bolts) and hardware DOT Approved (Department of Transportation) Two rear hoses included.
