Atomic Performance
Authorized Vendor
Hey Everyone, We have a special going on the T/A Performance rear end girdle and stud kit. After your forum member $10 discount it is $169.90 shipped to your door. This is a great product and one you should have on your Mustang if you don't already. Some features include:
-356 Aircraft Grade Aluminum
-CNC Machined
-Fill Port & Drain
-Bearing cap preload studs which are there to prevent the bearing caps from bulging out under load (hard launches).
-Lower differential operating temperature of around 15* which will help prolong the life of your rear by preventing the fluid from breaking down.
-These girdles also increase overall gear fluid capacity by approximately 1/2 a pint.
Let me know if you have any questions, Thanks, AP
TA Performance Girdle
-CNC Machined
-Fill Port & Drain
