Technical help from companies i wrote while on deployment
While i was on deployment I wrote a couple companies with my mods list and my idea of a bulletproof T-76 turbo'd cobra they all pretty much wrote me back all were thankful for my service and all gave great info these are their responses:
Hellion Power Systems and Turbo Kits:
Mr. Van Patten,
First off, let me thank you on behalf of all of us here at Hellion for serving our country and allowing us to continue this hobby of ours. Also, I'd like to thank you for your interest/compliments regarding our kits, we appreciate it.
Now, regarding the car - I looked over the sheet you attached, and it looks as if you have a great start on your hands. First and foremost as far as engine modifications go, the absolute most important thing to do is to build the bottome end of the engine as strong as possible. This is especially important with a forced induction setup, such as our kit. This will yield the best results, and provide you with the most fun/longevity from the car/kit.
Now, everything besides the shrotblock would be considered secondary, especially on a Cobra. The 4-valve heads that come on thse cars flow incredibly well for a stock head, however, if you spend a little time and money to have them ported, they will flow nearly as much as a 302-based race cylinder head, or over 300 CFM. This kind of head flow is a good thing to have with a forced induction car, as the more air that you can get through the engine, the less boost you have to run in order to make power, which increases longevity.
Any of the mainstream manufacturers/distributors of Mustang parts will be able to help you out with engine performance parts. However, I would reccommend Livernois Motorsports as a great place to get your engine components, as well as your head porting. Also, BOSS 330 Racing is a good company to go to, as well as Modular Depot. Any one of these companies with have the parts for your engine on the shelf, and all of them are about the same in price.
With these Cobra engines, not a lot of engine parts (i.e. camshafts, cylinder head work, etc...) is really required to make a lot of power. You could simply build up the shortblock to handle the power, and probably make 800+ to the tires, no problem.
I hope this helps with your questions, if not, feel free to contact us the next time you get a chance, and we'll be happy to help you out with anything else you need.
Thanks again.
-Craig
D.S.S. Racing:
Dear James :
The list of parts looks good, but I don't know about the T-45 holding up to the new power this combination can make. What I have quoted for you here is a rotating assembly, a Main Support and a 7qt oil pan. We can also build this as a shortblock if you don't have access to a good machine shop that is familiar with the 4.6 engine family. For over 20 years we've been bringing you the highest quality in parts with state of the art machining technology. Countless hours are spent in preparing our engines, parts and kits to meet our customer's high expectations. Purchasing an engine from us allows you to take advantage of our investment in cutting edge CNC technology and 20 plus years of Ford Racing engine building experience. Bottom line: long lasting, record setting performance at a reasonable price. This sort of quality, longevity and performance is only available at D.S.S.!
Thank you for your interest in our products. All estimates can be adjusted to fit your specific needs. This is just an estimate so it's easiest to make changes now. For questions or adjustments please contact us at 630-587-1169 or ecom2000@dssracing.com You will also find more information on the web at www.dssracing.com
Quote is valid for 10 days
Estimate
Date
5/6/2008
Estimate #
16401
Name / Address
James Van Patten
Salesman
EGD
Thank you for your interest in our products. Here is the quote you requested.
Total
Subtotal
Sales Tax (8.0%)
Item Description Qty Cost Total
RA4.6X7-4854(4V)
4.6 forged 4.6 forged 8-bolt crankshaft (3.543" stroke) 650.00 650.00
DSSRD5933-HBEAM DSS 5.933" 4340 forged H beam rods with 4.6L rod journal and
.866" pin. Finished and sized, includes ARP 2000 cap screws
599.95 599.95
4854-20 4.6/5.4 4V 1.22/3.572/.866/-12cc Max Quench dish Extreme X
pistons
599.95 599.95
E-916K-.50MM 4.6/5.4 ductile iron, plasma-moly rings 1.5mm - 1.5mm - 3.0mm
- .50mm/.020" over
99.95 99.95
CB-1442P (8) Clevite 4.6/5.4 rod bearing STD, TM-77 material 54.95 54.95
149M-STD Federal Mogul 4.6 aluminum block Super Duty Alloy
competition series main bearings
89.95 89.95
BALANCE 4.6 KIT Balance 4.6 rotating kit 175.00 175.00
X7 4.6 discount -124.80 -124.80
4.6 X-7 Rotating Assembly with Max Quench dish top,with 4V
flycut pistons. Includes DSS/KPC microalloy forged 3.543"
stroke crank, DSS forged 5.933" H-beam rods w/ ARP 2000
bolts, forged DSS Extreme X Series pistons, ductile iron moly
rings, and tri-metal bearings. Computer Balanced to racing
tolerances for easy assembly.
2,144.95
1030 DSS 4.6/5.4 Main Support System
3/4" billet aluminum w/ custom ARP main studs
359.95 359.95
OP7050 DSS 302 low profile 7qt oil pan with pickup and front
passenger-side 3/8" NPT baffled oil return hole (for
supercharger/turbo). Works with most short and longtube
headers.
299.95 299.95
$2,804.85
$2,804.85
$0.00
MMR Modular Mustang Racing:
Hey James, well i would recommend getting our Street Mod 900 Rotating assembly or our Street mod 950 Stroker rotating assembly. also you might want to upgrade the springs in your heads and get ARP head Studs and our head gaskets. i was not able to open your spread sheet, so i could not look at you list, but please let me know if you have any other questions, and i understand about the whole internet thing in the gulf becuase i was in the navy too and it sucks trying to find anything on the web. but please let us know how we can help.
My response:
Chris,
So should I get the short or long block 900? I would like to replace the “top/bottom” end parts to ensure nothing will break under pressure from the T-76 turbo. I’m referencing your company because I’ve heard nothing but good, plus your location isn’t too far from San Diego. Ill copy and paste my modification sheet in this email for you to look at. The stuff in red is stuff I have already purchased and stuff in black is stuff I would like to. I haven’t included prices for engine, tranny, clutch, flywheel because I’m looking for your guidance from MMR and their great products. I really appreciate all your time and input.
their response:
Hey James, well both options are great, but if your heads are in good conditon than there is no reason to buy new ones we can just makes yours better. i think really for what you are trying to do you would be happier with a stroker. i hope this helps if you have any other questions feel free to ask, and from the list the car sounds bad..
this is pretty much the summary email i wrote everyone just worded it differently towards other companis:
To Whom It May Concern:
I am in the military and am currently deployed in Iraq have just recently reenlisted and received a selective reenlistment bonus. I would like to spend a nice chunk of it on a 76mm turbo kit from Hellion for a 1996 Cobra Mustang with approximately 110k miles on it daily driver. I am writing you because my internet is limited and would like some advice. I would like to know what type of engine parts I need to replace to ensure the kit is most effective and least chance of hurting the engine. I know your company has a huge selection of engine upgrades for the engine. I would like to upgrade parts of the engine “top/bottom end”. What products do you recommend to purchase parts to fit my engine? I know people probably write you all the time with questions like this and I apologize. I have read many articles on mustangs with your parts and heard nothing but the best. Attached is a list of things I have thus far on my car in the excel sheet. Red is items I already have and black is to buy list with in the next 9 months. There is no virus or spam attached as this is coming from a military computer. I am looking to order the items recommended towards the end of April once my bonus is deposited. Your time and assistance is greatly appreciated. Thank You
Very Respectfully
James E. Van Patten
Livernois Motorsport:
Mr. Van Patten,
To answer your question regarding the engine parts, I would recommend our 298ci stroker shortblock. You would want our 18cc 8.8:1 Compression shortblock for a turbocharged application, which retails for $4,395.00 + freight. If you have any other questions, please feel free to email me back. It sounds like you’re building quite an impressive vehicle.
New Iron Block
Custom Livernois Forged Steel Stroker Crankshaft
Livernois Exclusive Mahle Forged Pistons
Mahle Rings, Locks, and Wrist Pins
Livernois Exclusive Manley H-Beam Rods w/ ARP 2000 Bolts
Clevite Tri-Armor Coated Bearings
ARP Main Studs
No Core Charge
Limited One Year Warranty - Click here for Details
Clevite Tri-Armor Coated Bearings reduce friction and increase durability
Livernois Exclusive Mahle Custom Pistons have thicker ringlands and cross section than any piston on the market for big boost and power
Custom Livernois Rod designed in conjunction with Manley is now industry standard
Livernois Forged Steel Crankshaft good to 1200+ HP and modified on Livernois in-house CNC for enhanced oiling under extreme loads and RPM
Products are built in climate controlled clean rooms so all specs are consistent
During the build process, each step is checked and rechaecked to ensure proper assembly
Each shortblock includes a detailed verification and spec check sheet
More shortblock combinations and specific power adder applications than anybody on the market
We ask you to compare our shortblocks against the competition
Livernois Motorsports shortblocks are put through grueling test sessions on the dyno where our stroker engine package was first developed. Then hours of rigorous track testing was done to make sure we had a bulletproof package.
100s of hours of development and testing
100s of hours of cylinder finish development with state of the art Mitutoyo Profilometer to come up with a Livernois Exclusive honing system and finish that seals better and makes more power as well as controls oil and extends ring life
Lighter weight pistons than anybody in the industry for better RPM capability
Grafal coated Mahle pistons and phosphate coated ringlands and pin boss reduce friction and are standard in every Livernois Motorsports shortblock
Thicker tool steel wrist pin than any other piston manufacturer on the market is standard in every shortblock
Every block is race prepped by hand and is throughly deburred
Block oiling system modified for better oil flow and more consistent pressure under extreme conditions
Tighter tolerances (+/- .00015) than anybody in the industry
Every Livernois Motorsports built Rotating Assembly or Short Block is assembled by hand with the utmost attention to detail. Balanced and blueprinted with strict tolerances for quality, reliability, and performance unmatched in the industry! Livernois Motorsports has taken its experience in building winning race engines and applied that to its own line of performance engines for street/strip applications. From deburring and radiusing the blocks and pistons, down to the environmentally controlled clean room assembly procedures, Livernois Motorsports is confident that it is providing the customers with the highest possible quality in every engine that is built!
Regards,
Rick LeBlanc
yeah np i posted it for ur situation but also to get advice for mine as u did yours
mulethras
wow thats pretty cool maybe i should start doing something like that for a v6 and post it for the 6ers maybe even get them to sponsor us or something
it still can be im not in any way shape or form saying its not possible. its just hard
