Ronnie Friedline
ok bored to 4.030, puts to 306, carb setup with weiand stealth dual plane intake power range from 1500 to 6500 rpm, heads worked with oversized valves and springs, with 1.6 chrome molly roller rockers, hydraulic flat tappet lunati voodoo cam 528/536 lift on factory rockers, with a 268/276 duration, yes split lift and duration, and its on a 110 lobe seperation, ground crank, hypereutectic keith black dome top pistons with valve reliefs, with matching rods, hardened pushrods, Went hypereutectic cause it can handle more heat. motor is at like a massive 12-13:1 compression ratio with everything current. Wanting 1500
