Barona Test & Tune-7/24/09
104 didn't do the trick?
No, its more then that. There's no knocking or anything. Car ran good as far as no mechanical problem. Can't hook at all last night. Burn the **** out of the tire, just not hooking. Those Nitto DR sucks, I"m convinced of that now. But looks like yall are right about a stall kit. Just can't get the rev up high enough to launch good.
I know, its an auto and only so much it will do. But 9.2 on the first run and just keep running a 9.4 all night. Oh well, just have to keep trying.
How do you launch? Sometimes loading the car by revving it as high as you can before it moves isn't the best way. You have a low stall from the factory, so in order to get the converter to flash you would have to just mash the throttle from idle. The car may take off quicker than the way I've seen you launch.
If you haven't already tried that, give it a try next time out. :)
Post your slip stats from the first run.
well it was good night for the stang,
60' 1.68
330' 5.08 at 62.78 mph best
et 7.922 at 88.820 mph
60' 1.660
330' 5.078 61.867 mph
et 7.943 at 88.028 mph
this run i adjusted the struts to #2 and produced the best 60' i have ever had
60' 1.706 5.115
330' 5.115 63. 132 mph
Et 7.941 at 88.894 mph
even though i got off late as hell from work i made the most of my night and stayed consistant through the night, my first 2 runs were 8.1 and a 8.0, the car was hooking pretty good all night long....well have to see what happens when i come back in october....
Lordgufi
couldn't go. had to return money on that pc i sold. turns out the mobo is dead... tested all the other hardware today to figure that out -_-
I love watching 02GT race, He launches like a bat out of hell.
Awesome! Looks like Eric is hitting 7's with some consistency now. Anti-roll bar would probably get you a 7.7 E.T.
What were the outside air temps last night?
it was in the high 60's after 10 last night and that was when i was cutting the 7.9's....
I can only rev up to around 1500 rpm before the car wants to go. But I mesh it on the green. But I threw all my time slip away because I was so disgusted.
Misled20
my first run s good, then the track started to feel like racelegal. i some how managed to hook up on my last run and now have my new best time
Next time out do not rev it up at all. Just get staged and let it idle. On the last yellow mash the throttle! I'm willing to bet your times will improve.
If it hooks that is. :)
Next time you drive it play with it from a dead stop and see which method gives you more seat of the pants.
I'll try that next time. I'm willing to try anything to get an improvement. Thanks.
Within an hour. I only took like 30-40 vids. This is my first time taking vids too, so excuse my amatuer photography. Next Time I'll do a lot better.
