I
Ichiduo
Thanks. That helps. I, too drive with the overdrive on and trac control off. I have street tires right now. I only can get up to about 3000 rpm when I roast them (I may be doing it wrong) and the rpm start to drop off at that time. and I launch at about 2000 rpm, it seems thats when it starts to break.
I'll try what you do next time I get on the track. Thanks again for the help.
is your car tuned? like do you have an xcal, diablo, sniper, etc? i need to look at my programs, but your car only being able to get up to 3000rpms when doing burnouts is weird. my v6 got up to 5000-5500 rpms when i did burnouts. not much smoke though cause the tq was only about 200 or so.
if you don't have a tuner, that may explain why your car is cutting you off at 3 grand when you're trying to do burnouts. if you do have a tuner, see if you can play with your tune so it'll let you rev higher.
launching at 2000 rpms seems right though, cause i was at max launching at 2200. if you fix your revving issue, you may be able to do longer burnouts and with stickier tires, means higher rpms you can foot brake at (tires grip more, rev higher).
jus some other things to try.
