Foxmand the photos did show.. You can use the upload button..Got the car running was working on tune when engine lost oil pressure.. I knew I should have put a new pump in it..oh well time to pull it back out check bearings and if everything is ok replace pump.. Here is what it sounded like.. Oh and shifter needed to be adjusted, wasn't getting 1st gear had to test in 2nd
