June 12 Test and Tune
Superstang21
YOu put slicks on that car and it will be in the low 11's your mph is already there... The only problem is once the tires grab your clutch is going to slip... so then tires and clutch is the next mods to do.. I mean whipple said that the blower and boost your at is fine for your setup
Yeah, I still want the forged internals though... But I must say after last night at the track I have far less fear that I am going to grenade my motor. I didnt hold anything back last night and it ran flawlessly!!! Hats off to Whipple!!
fangs99
Dont get your hopes up because I will learn how to launch this car and it will be on like donkey kong:rofl: It pulled great as soon as it hooked because I should be around a 12.9 with that MPH. Anyways good time nonetheless, and it was great to see Joe's car gettin it done. I bet with a good set of slicks he will be in the 11's no problem.
well i wouldn't be makin a statement like the one i made if i didn't have plans to back it up. with my new suspension, gears, trans, and that outher thing thats in the works.... i should be bottom 12's-mid 11's no prob. i'll let ya'll guess what i got planed but i ain't telling
fangs99
while we are talking about the 1/4 mi what are the tracks rules on ET vs safty equipment? how fast will just a helmet get you?
SIC FIDDY
I think just a helmet will get you to 10.9. Anything quicker requires a cage I think. Dont quote me on this one.
zimmerc
Drive shaft loop required on all cars running 13.99 (*8.59) or quicker (except vehicles running 13.00 (*8.14) or slower cars equipped with street tires) After market axles and axle-retention device mandatory on any car running 10.99 (*6.99) or quicker and any car with locked differential. Cars running 10.99 (*6.99) or quicker that weigh more than 2,000 pounds (907 kg) with independent rear suspension must have swing axle differential replaced with conventional differential housing assembly. Transmission shield meeting SFI Spec 4.1 mandatory on any car running 10.99 (*6.99) or quicker or any car exceeding 135 mph (217.2 km/h). Automatic transmission flex plate meeting SFI Spec 29.1 and flex plate shield meeting SFI Spec 30.1 mandatory on cars running 9.99 (*6.39) or quicker or any car exceeding 135 mph (217.2 km/h). Four-wheel hydraulic brakes mandatory on any bodied car running 7.99 (*4.99) or quicker. Minimum two rear-wheel (one calliper per wheel) hydraulic brakes mandatory on Dragsters, Funny Cars, and any car running slower than 8.00 (*5.00) seconds. Dragsters running slower than 10.99 (*6.99) with a total car weight of 1,000 pounds (454 kg) or less and a one piece rear axle may use a single brake rotor with dual callipers. Roll bar mandatory in all cars running 11.00 (*7.00) to 11.99 (*7.49) and in convertibles running 11.00 (*7.00) to 13.99 (*8.59), and in dune-buggy type vehicles running 12.00 (*7.50) seconds and slower. Permitted in all cars. Roll cage mandatory in cars running 10.99 (*6.99) or quicker, or any car exceeding 135 mph (217.2 km/h). Full bodied cars, with unaltered firewall, floor and body (from firewall rearward, wheeltubs permitted), running between 10.00 (*6.40) and 10.99 (*6.99) roll bar permitted in place of roll cage. Cars running between 7.50 (*4.50) and 9.99 (*6.39) must have chassis inspected every three-years by the ASN and have a serialised sticker affixed to cage before participation. Seat belt mandatory in all cars. Three-inch (7.6 cm) driver restraint system meeting SFI Spec 16.1, mandatory in any car running 11.99 (*7.49) or quicker and in convertibles running 13.99 (*8.59) or quicker, and Dune buggy type vehicles running 12.00 (*7.50) seconds or slower. SFI 16.1 restraint system, when required, includes crotch strap, and must be updated at two-year intervals from date of manufacture. Drivers in all 13.99 (*8.59) or quicker cars, and Dune buggy type vehicles running 14.00 (*8.60) seconds or slower must wear a helmet meeting SNELL 85, 90 or SFI 31.1, 31.2, 41.1 or 41.2 Specs or BSI BS 6658-85 type A (including all amendments) Specs. Driver's in supercharged front-engine open-bodied cars must wear a helmet meeting SNELL SA95, SA90 or SFI 31.1 or 31.2 Specs or BSI BS 6658-85 type A
Nice run Joe with more practice on the street tires I can see you getting in low 12's. When I launch mine I usually slip the clutch and try to come out of the hole like I am leaving a light on the street. I just slip it and take off fast. I usually pull 2.0 and I ssn best of a 1.8 on my street tires. Last night I pulled a 2.0 60 ft and ran a 8.3 in the 1/8th I cant wait to get back from deployment. I am doing forge internals, heads cams ect.. Nice runs bro. Did dustin go with you guys? His car is getting some good ET's too isnt he?
Superstang21
Thanks Phil, dustin didnt make it this time. He had to do the daddy thing, couldnt find a sitter....
