Anderson Powerpipe Installed
Started installing the Anderson Powerpipe yesterday and started the car up today.
First I had to expand the 3.5" hole in the engine bay fender wall to 4":
After I finished the expansion, I added the trim around the hole and then inserted the pipe:
Once the pipe is into the fenderwell, I hooked up the head unit (removed for install) and inserted the hard rubber elbow to the head unit.
Then I attached the MAF (had to pull the wiring harness to get enough wire...YIKES) and the air cleaner. Now I have to manufacture a plate to cover the hole and make a true cold air intake.
Here is the completed work!!!!!
before i put my pipe on i made 7 lbs and after i made close to 9 lbs, so that thing is deffinatly effective but it throws off the air/fuel alittle bit.
Nice Todd! Did you drive it yet? I'm curious to know if you gained any boost?
I have not run the car yet, but I'll know tomorrow when I go to "Beef and Bun"
Tommy, that's a new power mod, dont give away all my secrets. That's an Mexican Dizzy Booster.
