where am I contradicting myself? yes I did suggest a solid roller setup the other day but not if you plan on staying below 6000 rpms. but do what you want. now if you want to take that bitch to 7500 rpms, then now we're talking solid roller.
You don't have a clue what you are talking about. Just because you have a solid roller doesn't mean you need to rev through the roof. Solid rollers create stability in the valvetrain. That's why they can rev higher, but they will also make more power throughout the rpm range because of that stability. There is no rule that says solid roller = 7500rpm and hyd roller = less.
The stock rev limiter is 6250 which also shows that the rev limiter has nothing to do with this issue. As for the exhaust back fire........what do you think is going to happen when valve are floating? No Sh*t huh?
David you can come over when the process begins if you want some schooling.
