4 valves are garbage.
I would have had you in the 1/4. maybe not from a roll but definatly from a stop.
nnnnaaaaawwww you dont want that hunk of junk in a car!!!! you want to put a real motor in a car,,,, ya know somethin more like a 4v!!
ur crazy dude,,,, 4v isnt the way to go,,,, its the only way to go!!!
all them other options leave too much to be desired!! you can pull stupid amounts of power out of a 4v that a 3v wouldnt be able to see without extensive work,,, but hell,,, if you like pullin your motor apart every time you want to get a few extra points on the board then by all means!!! lololololololololol!!!!!
oh and by the by,,, the heating problem that the 4v was said to have was nothing more than ac condensers being too thick,,, not allowing decent cooling. which is the first mod that many 4v owners make,,, because they know with great power comes great responsability,,,,,,, but with the 3v,,,, yall dont have to worry about that,,,, lololololololololol....
Bring em. That is if your Clutch will hold up and your rearend doesn't fall out. And I'm sure I won't get you when you are on the bottle but let's go
