1. Hello there guest and welcome to our forum!
    Dismiss Notice
  1. BlueStallion5.0
    BlueStallion5.0 Well-Known Member Donator
    429
    0
    221
    ight sometimes when i get on my car feels like is kinda spudering (feels like its trying to get gas or air) really hesitent
    my neighbor said it could be my heads and my o2 sensors are shot gotta get elimanators but whats your guys opinion
  2. Mustangcwo
    Mustangcwo Guest
    I would not eliminate the O2 sensors. Your car will run better if it can read the output of your exhaust.
    Questions:
    How does it run at idle?
    Did you run a diagnostics on the car?
    Does it do it cold or just when it's warmed up?
    Are you running an EGR?
  3. Tommy
    Tommy New Member
    2,649
    0
    0
    check the sprak plug wires and spark plugs. Cracked ceramic on plugs can cause a mis-fire. Check for plug wires which may have come loose from the coils or spark plugs.
    I had the same feeling on the 90 Notch. Works great now.
  4. Mustangcwo
    Mustangcwo Guest
    I would like to help, but there are so many things that can choke a car. Sensors, plugs, wires, smog devices, dirty throttle body etc. etc.
    Do a diagnostics and get the codes. It will narrow the possibilities and allow us to point you in the right direction.
  5. BlueStallion5.0
    429
    0
    221
    How does it run at idle? idles good
    Did you run a diagnostics on the car? yea came up with o2 sensors
    Does it do it cold or just when it's warmed up? warmed up
    and it doesnt seem as loud as it used to be
  6. BlueStallion5.0
    429
    0
    221
    also i usually feel it in 3rd gear around 3.4 and 4 k rpm
  7. BlueStallion5.0
    429
    0
    221
    im looking at my haynes book right now for
    hesitation or stumble during acceleration
    1. ignition system not operating properly
    2.dirty/clogged fuel injectors
    3.low fuel pressure
    4. fuel injection or engine control systems malfunction
    engine lacks power
    mainly spark plugs
    low uneven cylinder compression (hope its not that)
    im starting to think spark plugs or fuel injectors my car did like when i put fuel injector cleaner in it a week ago
  8. Mustangcwo
    Mustangcwo Guest
    Change the O2 sensors first. Believe it or not, that could be the entire problem. They are relatively inexpensive and easy to change. Just unplug the sensor and then unscrew them from the car.
  9. BlueStallion5.0
    429
    0
    221
    ight ill do it today i already have some from before
  10. kakarote
    kakarote Well-Known Member Donator
    293
    1
    233
    don't leave out the fuel filter. it causes same problem at speed.
  11. BlueStallion5.0
    429
    0
    221
    FIXED it doesn't do it almost at all thanks everyone i put on new spark plugs, fuel filter and cleaned my air filter and did fuel injector cleaner thanks again everyone for your help
  12. Tommy
    Tommy New Member
    2,649
    0
    0
    Glad it worked out!
  13. Foxman
    Foxman Well-Known Member Donator
    3,925
    14
    253
    did your check engine light for o2 sensors go away... i see you didnt change your o2 sensors??
  14. BlueStallion5.0
    429
    0
    221
    not yet i got them i just havnt had time my grandma is in the hospital so im barly havin time to get on here
  15. sdsubzero4
    sdsubzero4 Spring Valley, CA San Diego Chapter
    15,733
    1,531
    458
    Automobile:
    2014 Mustang GT
    All the best to your grandmother.
  16. 02gt
    02gt Well-Known Member Donator
    3,287
    0
    251
    i feel ya man, my moms dad is on the way out, if you catch my drift....
  17. BlueStallion5.0
    429
    0
    221
    yea they found a blood cloat in her lung and leg but they gave her blood thinner so hopefully that works
  18. 4CEFED
    4CEFED Well-Known Member Donator
    53
    0
    221
    I would also run some seafoam through the intake manifold, the IRMC's are supposed to open at the same RPM they might be a lil gunked up, just a thought but it seems you have it worked out. I did it on my cobra and it was noticably smoother.
  19. BlueStallion5.0
    429
    0
    221
    ACTING UP AGAIN idk wtf could be happening i got my stock headers on could it be too restricted? what are the signs on bad heads? or could it be the fuel pump
  20. 02gt
    3,287
    0
    251
    do you have a tuner(sct or diablo)? If so hook it up and let is record the fuel pressure, it shold be around 40 psi....
Share This Page
