clutch questions
Wow I was wondering what the hell was going on. I was like the pilot bearing is in the Crankshaft! Anyway good call on the TOB. I didn't think of that one. I think they were aluminum in the foxes and 94-95 changed to steel ones. The steel is the way to go.
Beejay I have a whole T-5 for $300 with a steel TOB.
Windveil Blues
OLD FART
If it's in good shape Beej, might not be a bad deal for you. Even if it works as a temp while you rebuild your other tranny.
dont have the money man...the whole car is falling apart. right now i am saving to put my rear end back together. after that i will worry about the transmission
DSGimportslayer
DSG in the hisouse!
just an idea but a quick trip to the junkyard might fix your rearend problem for the time being, i went and got two axles from there just last week and fixed my buddys 90 fox. i can help if you need it.
i wish it were that easy. i love junk yards. the problem is the bracket that the control arm mounts to. the one thats welded into the body. that weld is torn up and ripped
DSGimportslayer
DSG in the hisouse!
i can weld i just dont have access to a welder, you could just swap out the whole rearend, just need a 8.8 rear housing and just swap everything over. back on the road in a day.
the axle and rear end are fine. its body thats messed up. i got a buddy that has put some cars together who is really good at welding. we are gonna just rip it the rest of the way out, and put it in stronger
see any sn95's at the junk yard? i dont know what i could get from there but hey just curious of yall seen any.
I'm actually gonna go to the junkyard this weekend to try and find an sn95 rear end with disc brakes to throw on the fox. Then I'll be selling this rearend, which is 5lug, but has drum brakes. Also has 3.73's with less than 2000miles if anyone is interested.
3.73's for which rear end? let me know if you see any sn95's at this point in time i dont need anything really from them but its good to know if there are some there
