car trouble
kalop
Lemoore,Ca
anything with a sensor will pop a code.... fuel pump and fuel pressure regulator wont even a bad injector wont throw a code itll just act up. its in your fuel system or a bad plug wire.
kalop
Lemoore,Ca
american muscle has them summit has them online or you can call parts recycler theres a few out there that sell quality parts for alot less cost. but im still saying its in your fuel system.
well lets put it this way every time i clean it it runs alot better but like two times after running it it starts to act the same way again so it most likely is does anyone know were i can get a new stock MAF for the car? and about how much it will cost
wouldent it pop codes if it was the MAF???
The MAF is a dealer item..
kalop
Lemoore,Ca
yea your maf (sensor) is controlled by the cars computer and obviously has a sensor that would throw a code or pop the check engine light, if it had a malfunction.... turn your key see if your injectors build pressure by pushing the bleeder valve on the front of the fuel rail on the drivers side, if theres no pressure fuel pump nine times out of ten, start cheap change your fuel filter first then go fuel pump just make sure to hit the dealer for the filler neck gasket that most times you will tear up dropping the tank.
kalop
Lemoore,Ca
you can go to www.modularmustangracing.com and get a mass air sensor from them 139.99 its a 90mm upgrade like the lightnings use its 15rwhp bonus as well... if thats the route you want to try first. their on the coast camarillo,ca. but these guys are mod specialists and build some seriously powerful modular engines.
