i agree with sinful except for the aluminum flywheel. id go with something that can be recut and reused. the aluminum one is only 11 lbs but they are riveted together, id go with a one piece chromoly one.
and as for daddy looking over your shoulder....i dont have that problem. nobody tells me what to, they trust me to get it done right.
Sinful said:S-trim V2 with a nice bypass valve and power pipe with a 10 rib pulley setup
Holley system II intake
50lb injectors
Edelbrock RPM heads or AFR 185s
Custom blower cam (with the right valve head springs for the cam)
302 stock shortblock (if yours is still healthy)
Good balancer, aluminum sfi flywheel, custom clutch or centerforce dual friction with a king cobra pressure plate.
T56 transmission
02gt said:BJ, I dont know if you read muscle mustangs and fast fords, but i find a lot of articles about budget fox body bulids, they had a stock engine with a turbo that had more then 200,000 miles on it and they made about 600 HP with just new head gaskets, they ran it up to about 16 PSI, so maybe you might want consider that, i'm not sure if your yeah came with forged internals but i know some of the later years did. I have ton of the mags so if you want to take a look i can give you some of magizines.
